tank selection front to back
Old Apr 13, 2004 | 07:29 AM
lilboysdrivebowties's Avatar
lilboysdrivebowties
Is there a procedure in the owners manual on switching tanks, like, only while idling or anything like that. I don't have an owner's manual. When I switch tanks I have to be idling because the tank that I switch to acts like it's not primed and I get a back fire or miss. This morning I switched from the front to back and it wouldn't clear up so I switched back to the front. About a mile from work I switched back to the back and did fine but I have to let off the gas for a minute, then get back on the gas. Normal??
Old Apr 13, 2004 | 07:35 AM
LoosMaster's Avatar
LoosMaster
No, this is not normal. What year is your truck? The only thing I would recommend is not running your tanks dry. The pumps require fuel for cooling.
Old Apr 13, 2004 | 08:11 AM
lilboysdrivebowties
92 f150 4 x 4 w/ 351w
Had 1/2 tank in both...
Old Apr 13, 2004 | 08:25 AM
LoosMaster's Avatar
LoosMaster
I would check the fuel pressure on the injector rail while selected on the front tank, then switch to rear. If there's a large difference, then I would suspect the rear FDM(FuelDeliveryModule) in the rear tank is defective.
Old Apr 13, 2004 | 09:06 AM
lilboysdrivebowties
if it is, would it be better just to replace it all while I'm there?
Old Apr 13, 2004 | 09:14 AM
LoosMaster's Avatar
LoosMaster
Yes, you can't service this unit like the old one.
Old Apr 13, 2004 | 09:16 AM
lilboysdrivebowties
thanks for the advice
Old Apr 13, 2004 | 09:19 AM
LoosMaster's Avatar
LoosMaster
Post back and let us know what you found.
Old Apr 13, 2004 | 09:20 AM
lilboysdrivebowties
will do. might be a few days. Thanks again.
