Hesitation when under load......
Old Apr 12, 2004 | 11:26 PM
TDBRPH's Avatar
TDBRPH
Recently changed the fuel filter and had the transmission fluid changed. The tranny fluid change really seem to cure some up/down shifting issues I was experiencing on the hills on the highway. The question I have is that under no load ie... parked or neutral the engine response is very good however when under load most commonly occuring when trying to turn across traffic or quickly accelerating from a stop I am experiencing a significant hessitation the RPM seems to remain consistent so it leads me to believe the problem lies in the transmission. 2000 EB 4x4 5.4 with 72k. Any ideas or suggestions would be appreciated.
ps what RPM should the 5.4 idle at? Both 5.4's I have owned have been rough idlers am I just lucky.
Thanks
Triston
Old Apr 12, 2004 | 11:50 PM
buzzard's Avatar
buzzard
Yeah, it sounds like you might have excess slippage in the tranny.
Some other areas of maintenance you might want to consider are plugs, clean MAF sensor, clean injectors, clean TB (ooops Ford says not to), pcv, etc. You're getting up there in miles and it wouldn't hurt to address these items.
The 5.4L should idle b/w 600-700 in gear.
Mat523
Jun 25, 2015 04:31 PM
poobah47
2004 - 2008 F150
Jan 11, 2014 08:34 PM
spiggy769
Modular V8 (4.6L, 5.4L)
Jan 9, 2013 11:30 AM
Dascro58
Jun 4, 2012 07:22 PM
JnSCald
All Things Towing
Jun 17, 2011 08:53 AM
