This is okladrop, I just put on an Mas Intake and a Granatelli Mass Airflow on my 97 F-150 4.6, and the check engine light came on and stays on.
I disconnected doth battery connection and now I'm just waiting until later on today to reconnect them and see if that will help.
Do any one out there have some guidance for me
v/r okladrop w/a bad ck eng light on.
All F-150 riders I look at some of your issue and went to autozone, code#113 came up in the scanner the connector was not hooked up, daaaa, any way the check engine light went off as fast has it came on.
Thanks Autozone. Hooha!!
Hi again,
If you check out the Chips and Tuners forum which is a little ways further down on the main forum page the guys there will be able to answer any questions you have.
I have only had limited experience with chips and tuners.
To see what is available take a look at the parts store that helps keep this site open. The link is at the top of the page and also in my signature.
