fuel pump problem
Old Apr 12, 2004 | 08:04 PM
jsea's Avatar
jsea
fuel pump problem
this my 1st time need some help fuel pump seem to be not working replacd relay switch checked fuses all good had been driving all day then went to start truck and all it would do is crank heard no fuel pump running any suggestions what might be wrong and/or how to trace down the problem the rear tank was making a high pitched sound before i have replaced front fuel pump about 5 yrs ago have read repair manual and tried to trace wiring no luck if this is not the right place for help let me know Respectively jsea
Old Apr 12, 2004 | 08:17 PM
LoosMaster's Avatar
LoosMaster
Need more info, i.e., year, model, engine?
Welcome to FTE
Old Apr 13, 2004 | 07:05 PM
jsea's Avatar
jsea
fuel pump problems
im not sure if my quick reply made it through its a 1990 F-150,inline 6 300cid/4.9L, cali truck,with aITR fuel pump in mid shipe and rear tanks Thanx jsea
Old Apr 13, 2004 | 07:40 PM
LoosMaster's Avatar
LoosMaster
If I understand you post correctly, the engine will not start on either tank?
Old Apr 16, 2004 | 12:59 AM
jsea's Avatar
jsea
fuel pump problems
yes that is right it will not start from either tank i am having trouble with puter it may take a little to reply thanx for your help jsea
Old Apr 16, 2004 | 07:31 AM
LoosMaster's Avatar
LoosMaster
The system has an inertia switch. Try to reset it. Located on driver's side in cab, up against the firewall, to the left of the brake pedal or behind the kick panel. Small black box with red button on top. Push it and see if it starts.
Old Apr 16, 2004 | 12:46 PM
jsea's Avatar
jsea
fuel pump problems
thanx a million the inertia switch was tripped a very good call this site is tops on my list i still not to sure about this thread thanx e1 that read and replied to my problem Respectively jsea
