diesel pedal
2001 F-350 CC Lariat 4X4 LB PSD SRW, Heated leather, off road package, western snow plow, strobe lights in parking lights, headlights and backup lights, tinted windows, stull billet insert, pioneer cd player, rockford fosgate 700S amp rocking 3 JL Audio 10W0's behind back seat,Infinity Interiors and an Alpine amp, husky liners front and back,Banks transcommand, K&N FIPK, ATS Ported Turbo Housing, Diablo Sport 110HP chip, Hypermax pryo/boost gauge, Hypermax 3.5 inch downpipe and 5 inch exhaust.
2002 F-350 XL 4X4 PSD DRW, XL Decor Package, 9' Heil Dump Body, 8' Western (for now) Poly Plow, Strobes Front and Back, toolboxes and Wheel Simulators.
>throttle and it seemed to add mo more power after that, like
>almost a dead space of pedal with no response.Is this a
>common occurance?
Fairly common. Wherever in the pedal travel the PCM receives the maximum voltage signal will be the WOT position, and pushing the pedal down further will do nothing unless you adjust/reposition the TPS (throttle position sensor) thats mounted on the pedal assembly.
<WIll a chip help with the throttle
>response, not just at full throttle but all around?
Yes.
Something else I just thought of. At your 85%-90% throttle, were you bumping the rev limiter (3400 rpm) or the speed limiter (~94 mph) if you were then nothing would happen with more throttle input and you could forget the rest of the stuff I just typed.
Most (if not all at this point) chips/programmers raise or remove the speed limiter, and some can be custom tuned to raise the rev limiter.
