Sponsored by: Real Truck
XM Roady install
Old Apr 12, 2004 | 06:47 PM
alfie623's Avatar
alfie623
XM Roady install
For those of you with a Lariat I found a nice place to put the Roady. I'm mounting it in the garage door remote compartment. I'm running the antenna through the middle roof clearance light and I have the fm modulator made for the skyfy to wire it into the head unit. I found the keyed power wire that operates the radio after the ignition is trned off and before the door is open. This keeps the Roady going until the door is open too. I'm not complete with the install but I had everything apart and it's all pretty simple to do. The hardest part is notching the middle clearance light mount to allow the antena wire through and sealing it the roof. I don't have pics yet but I can walk you through it.
