tachometer hookup
Old Apr 12, 2004 | 03:02 PM
boogity24's Avatar
boogity24
tachometer hookup
The tachometer on my neighbors instrument panel doesnt work. Everything else works, but the tach doesnt. What can he do to fix this problem???¿
Old Apr 12, 2004 | 06:03 PM
82F100SWB's Avatar
82F100SWB
Check the fuse in the warning lamp position(bottom left hand corner of the fuse box, just above the hole, should be 15A) The tach was the only thing on it in my F250.
Old Apr 12, 2004 | 06:49 PM
F 2fifter with a 4 sixter's Avatar
that or the tach itself is messed up i got one out of a junk yard that didnt work i put another one in that i found and it worked fine still dose
Old Apr 15, 2004 | 10:52 AM
DanMan7's Avatar
DanMan7
If those answers don't work, perhaps the two grounding connections inside the tachometer are spread apart. That would cause the tach to not work. That would happen if it's seen a lot of bumping around over the years.
Here's how you fix it, if you think that's the problem:
1. Unconnect instrument cluster.
2. Dismantle instrument cluster by first taking off outside cluster cover, which should use I believe 3/16" wrench/socket.
3. The front two plastic pieces should lift off.
4. Now loosen the tachometer nuts (the 4 nuts on the back of the tachometer) with a 5/16" socket/wrench.
5. Now the tachometer should pull out.
6. Loosen the nuts on the back of the tachometer itself (5/16" again)
7. Loosen the two phillips screws, one on each side of the tachometer casing.
8. Now the white cover should lift off. Make sure as you lift it off you push in on the bolts on the back.
Now, the way you check if it is good, there is one solder connection in between both circuit boards that is grounded all the way through. Also there are two wing-nuts on two shafts holding the two pieces together. Push the wing nuts all the way down on the two silver shafts.
Now to put it back together is the reverse of taking apart.
See if that works. I had that same problem happen in one of my tachs and now it works perfectly.
Dan
