Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Gasoline disposal
Old Apr 12, 2004 | 08:31 AM
VinMan's Avatar
VinMan
Question Gasoline disposal
How do you guys dispose of old gasoline?
Old Apr 12, 2004 | 10:30 AM
Huntsman's Avatar
Huntsman
How old? How Much?
Old Apr 12, 2004 | 11:50 AM
VinMan's Avatar
VinMan
It's pretty old, alot of it got dirty and contaminated with water. I have a few gals in cans , and also alot in a boat i got
Old Apr 12, 2004 | 04:15 PM
Andysutt's Avatar
Andysutt
Whatever you do, do not think "it looks like water, and you can't smell gas, so lets throw a match in it and see if it burns"
Ive seen it happen... it'll still burn
As for the disposal of it... If its like 20 gallons or so, Id put some "Heat" in it and let it work.. let it sit in a well ventilated area and let it evaporate, or call your local recyling center.
Old Apr 12, 2004 | 05:31 PM
beeboy's Avatar
beeboy
our local recycle place takes gas, and oil, antifreeze etc..
Old Apr 12, 2004 | 09:57 PM
FTE Herman's Avatar
FTE Herman
A match? And a big barrel?
Old Apr 12, 2004 | 11:18 PM
Bikeitswift's Avatar
Bikeitswift
Safe way
I agree with the evaporation route. If you are dead certain that no kids can get around it to experiment with, just set it out in the sun in an unopened container, over away from the house, it'll evaporate in no time. I put mine in my oil drain pan, which is about the size of a wash basin. Larger amounts I take to the same place I dump my waste oil.
Old Apr 13, 2004 | 12:17 AM
Torque1st's Avatar
Torque1st
Posting Legend
It is not good to just let it evaporate into the air where it adds to smog and air pollution. Call your city or county to find out if there is a disposal facility around.
Do not contaminate the waste oil center with gasoline or antifreeze. Make sure there are different containers for the different types of waste products.
Old Apr 13, 2004 | 08:23 AM
Andysutt's Avatar
Andysutt
At our local parts store they take any petroleum based product and dump it into the same barrel.
But, if it has one teaspoon of water in it, it ruins the whole batch, so I dont think they'll take it..
If your going to be burning brush or something of that nature, use it.
Depending on the amount of water in it, Id try to use some product like "heat" and use it...
Old Apr 13, 2004 | 02:21 PM
76supercab2's Avatar
76supercab2
If the situation is no professional collection available, I would go the evaporation or the burning brush (VERY VERY CAREFULLY) ideas over dumping it out. On a hot sunny day it will evaporate quickly. Just be sure there is no ignition source around.
Old Apr 13, 2004 | 02:27 PM
72stepside's Avatar
72stepside
Pour it in the backyard !!!!
(Calm down all, I'm only kidding !)
Light it!!!!
Old Apr 13, 2004 | 02:44 PM
Waxy's Avatar
Waxy
Call me crazy, but I'd use it. Unless it's REALLY bad.
Run it through a filter to get it as free from debris as you can, even if you do it 2 or 3 times.
Then separate the water. Just let nature take its course. Store it in a cool, dry place for a while, tightly capped. Then simply siphon off the top 1/2 to 3/4 of the container depending on how much water is in it. If you have a glass container (I use an old wine carboy) you can see the gas/water contact.
As long as it's not overly dirty, a little bit of water won't hurt things like an old lawn mower, rototiller, beater car/truck, etc... I do this with all of our old gas after storage etc... and have never had a problem. I even throw in gas mixed with 2 stroke oil.
The old '74 GMC doesn't seem to mind.
You can burn money (and sometimes I swear it evaporates) but why would you?
Waxy
Old Apr 13, 2004 | 08:19 PM
VinMan's Avatar
VinMan
Thanks for all the ideas! I was planning on the evaporating route, but was worried about the smell. but i'll try it anyway. The recycle center wont take it.
Old Apr 14, 2004 | 01:36 PM
kevin71100's Avatar
kevin71100
Old gas in as pump sprayer make a dandy weed killer, it nearly sterilyzes the ground around driveways. My highschool used it to mark the perimeter of the football field. Environmentally safe? Likely not but it works.
Old Apr 14, 2004 | 09:26 PM
redneckmechnic's Avatar
redneckmechnic
got any underground bees nests. we use it around the farm all the time pour a cup down throw a match in and run run run run.
