Which battery?
Old Dec 1, 2002 | 03:59 PM
jlande's Avatar
jlande
Which battery?
[updated:LAST EDITED ON 01-Dec-02 AT 05:01 PM (EST)]I'm rather new to the dual battery set-up and have a simple question. Since is getting cold here in Minnesota, say I run across a nice looking lady in need of a jump, does it matter which battery I hook-up to?
-2002 F350 Lariat Powerstroke
Old Dec 1, 2002 | 06:39 PM
13MWZ's Avatar
13MWZ
Which battery?
Nope, although I always use the one on the pass side just cause it's closer to the alt.
Old Dec 3, 2002 | 12:46 PM
Mizzou's Avatar
Mizzou
Which battery?
I have heard that one of the batteries is for the glow plugs and the other is for actually starting. Does anyone know if this is true?
Old Dec 3, 2002 | 01:05 PM
Saigon's Avatar
Saigon
Which battery?
Not true,
they both do all the work together, if you had only one you would never start !!
Old Dec 3, 2002 | 01:17 PM
vettehauler's Avatar
vettehauler
Which battery?
>Since is getting cold here in Minnesota, say I run across a nice looking lady in need .....
What are the odds.....
Drew
Old Dec 3, 2002 | 07:47 PM
bilder12's Avatar
bilder12
Which battery?
be sure not to jumb across both batteries at the same time, this will cause 24 volts to run thru the electrical system.
USE ONLY ONE BATTERY TO JUMP WITH and if ya find you need help with the chick, call on us!!!
Old Dec 3, 2002 | 08:23 PM
89greyghost's Avatar
89greyghost
Which battery?
actually yes it does if you need to jump use the drivers side,that is what my owners manual says. also you cannot force 24 volts to the sytem of the other car since the batterys are wired in parrell with a islare inbetween them.also you can start you vechical off one battery it just starts slow and causes some premature starter wear so i would not attempte it in the winter unless in dire straights
Old Dec 3, 2002 | 08:26 PM
89greyghost
Which battery?
