Column angel.
Old Apr 11, 2004 | 04:14 PM
helge's Avatar
helge
Column angel.
What is the angel for the columnbraket for a 55 F-100
In my truck it is straight forward 180 with a clamp and some rubber,
the column is moving up and down, not good for the gearbox I guess
Any tips in another way to fix this?
I think the column is in my gallery.
Old Apr 11, 2004 | 06:00 PM
merc546's Avatar
merc546
Helge
If you would go to search and type in Abe, in his gallery he has a good picture of the proper way the bracket is attached.
The bracket on a 56 is perpendicular (90 deg) to the column and then is attached with a small "-u-" ( a U shape with a ear on each side)piece of steel, in each of the ears there is a hole that matches the main bracket install a bolt and nut in each hole. Also there should be a piece of rubber between column and bracket
It looks like they used a muffler clamp on yours and bent the main bracket.
Hope this helps.
Chuck
Old Apr 11, 2004 | 06:10 PM
helge's Avatar
helge
No history
Thank you, I will try to make a new braket or bend the one in the car, and add new parts to lock the column.
I just all the extra thing that is put in without thinking about history
