first winter with diesel
Old Dec 5, 2002 | 10:16 AM
goalie's Avatar
goalie
This is my first winter and I have a few questions.I noticed the engine seems louder,not at warm up but all the time, is this normal?I recently went away and my truck sat for 4 days in the really cold weather and it started rough after I cycled the glow plugs a few times then after a few seconds of rough idle it kicked up where it is supposed to be.My question is should I change to 10w30 for the winter or just keep using the 15w40?I did not plug it in when i got back(didnt have time) but if I plugged it in for lets say an hour would it make a noticable difference in starting or does it have to be plugged in for a few hours?ONe more,I noticed the egt drop faster in the cold weather,is this the norm with everyone else, it seemed like I didnt need to idle it for as long as I normally do after the same type of drive.
Old Dec 5, 2002 | 12:36 PM
FDNY13's Avatar
FDNY13
Plug it in! I set a timer to start the block heater 2-3 hours prior to driving...quicker/smoother starts, considerably less smoke, faster cab heat. Mine sounds louder when cold but quiets down when warmed up.
I use ROTELLA SB 10W-30 in winter months only. (upstate NY) 15W-40 otherwise. Check your owner's manual for preferred viscosity at various temps.
I WOULD think your EGT would drop faster in colder months!
Hope this helps...
Old Dec 5, 2002 | 05:47 PM
jimandmandy's Avatar
jimandmandy
Post first winter with diesel
