With your help, just purchased a 98 Expy with 56K. Went to hook up the boat last night by inserting the handy expy device with the 4prong pig tail then hooking my trailer lights and none of my lights worked. Advice on next steps??
First check the compatibility of the connectors, some trailers dont have the same wiring scheme, and make sure the adaptor is inserted correctly as the previous owner may have broken the adaptor. Next check the fuses for trailer in the power distribution box under the hood. Get a test light and verify power to the various pins in the 7 pin socket and that the 4 pin adaptor is transfering the power to the correct pin. Ive seen quite a few of them broken or defective. Also check that the connectors to the trailor harness are actually plugged in.
True enough, HOmerwinzlow. I had to rewire my trailer plug to fit the Ford adaptor that came with my Expy.
I always start at the power source with the test light and work my way back. That way it eliminates a lot of false negatives.
OK I took the test list to the 7 pin socket and only got 1 socket to give me "light" on the test. None of the other sockets gave me a positive reading and by the way it was the socket marked negative on the little lid that protects the socket.
Needless to say when I tested the adapater I did not get any "light" either. How common is it to have a bad socket? The truck is a 98...think I need to replace the socket? I can't believe it is the trailer since the lights worked last summer and it has not been out of the garage since then.
I hate to say this because I get the same problem every other year. You have to rewire the plug. dirt get in there & raises hell with it corrodes it out. I have three trucks I have to do that to. Alot of the time I have to replace the 7 pin plug too. Good luck.
I have had to replace my 7 pin connector twice in the past 6 months due to corrosion. The first time, I had just picked up the Expy and it didn't have a cover for the 7 way.
Here is the color code using Ford's wiring harness with a new car-end connector. This can be picked up at any RV center.
1 - White - Common Ground
2 - Blue - Electric Brake
3 - Brown with White Stripe - Tail/Running Lights
4 - Orange - Battery Charge (+)
5 - Yellow - Left Turn/Stop
6 - Green - Right Turn/Stop
7 - Black with Green Stripe - Auxilliary/Back Up
This time, I used a hot glue gun and covered all the connections to help
prevent corrosion. I also covered the outside where the cable enters the
connector with a lot of electrical tape.
I hope that this helps.
Keith
Reason: add information
