General Automotive Discussion
Inside panel passenger door
Old Apr 11, 2004 | 12:48 PM
ragavitt's Avatar
ragavitt
Question Inside panel passenger door
How do I remove the panel from the passenger door of my 1995 Mercury Marquis. The window goes down real slow and I want to check to see where it is binding.
Thanks
Dick
Old Apr 11, 2004 | 03:49 PM
momalle1's Avatar
momalle1
You don't need to pull the panel for that, get some silicon spray and spray the guides at either end of the window, then run it up and down a few times. . If the regulstor is binding, there is nothing you can do to fix it, it's a cable type and would need replacement.
Old Apr 11, 2004 | 06:10 PM
ragavitt's Avatar
ragavitt
Smile Inside panel passenger door
momalle1, Thank you for the information, I will give it a try and see what happends.
Dick
Old Apr 14, 2004 | 08:42 AM
ragavitt's Avatar
ragavitt
Smile window binding
momalle1,
I tried what you suggested it helped a little but is still slow. Guess I will just have to live with it.
Thanks
Dick
Old Apr 14, 2004 | 09:49 AM
momalle1's Avatar
momalle1
Wait a day and do it some more. The silicon cleans and lubricates (you should spray your good windows while you are at it). If it doesn't work, I think you could probably have the entire regulator replaced for under $300, but there isn't much else you can do if you removed the door panel. It could also be a weak motor....
Old Apr 14, 2004 | 06:37 PM
ragavitt's Avatar
ragavitt
Thanks for the information. I did put some graphite on it and it seemed to be a little better. For $300. I will wait until It won't work completely.
Old Apr 14, 2004 | 08:13 PM
Racerguy's Avatar
Racerguy
A site with lots of info on the full-size Fords is http://www.crownvic.net/tech/index.shtml
