98 Expy front differential leaking
front axle, Very small leak only about a qaurter size spot on the grage floor.
Question: Is it just a matter of removing the axle, removing the flange
from the diff, installing the seal and putting everything back together.
Or is there more to it.
PS: Also noticed that the rear seal was leaking at the transfer case
I'm assuming here to just remove the shaft, Remove the old seal
and install the new one with the proper sized seal installer.
Thanks
BJW
