chips
Old Dec 6, 2002 | 09:36 AM
coachhomer's Avatar
coachhomer
chips
Everyone seems to like the chips in this forum, but everone seems to have "unrelated" problems that have a chip. I would get one, but am afraid to have problems. any opinions? any thoughts? how long have chips been available and has anyone had one for a while and not had any problems? just curious and trying to do a little research before making the decision. thanks
scott
2002 psd, lariat, 4x4, cc
Old Dec 6, 2002 | 09:43 AM
bricot's Avatar
bricot
chips
Haven't had any problems with the Supertuner. The Diablo didn't have a model for my truck or I may have picked it up, the switch on the fly has a certain appeal. However, the easy of use with the microtuner (no installation like the chip) is nice too. Not disappointed with the tuner at all. Love the extra horses and fuel mileage.
Old Dec 6, 2002 | 10:20 AM
Distinctive Dave's Avatar
Distinctive Dave
chips
I have had my chip for 28,000 miles,(put it in with 1,000 miles on the truck) and i actually went from a 80HP chip to a 78HP to a 110HP. The extra power is awesome and as long as you keep your foot off the throttle you get better fuel economy. I would still say with any chip get gauges. Boost and Pyro are suffcient. I have really had no problems just the occasional oil leak from intercooler tubes, and a high pressure oil line which is fairly common on stock PSD'S.
2001 F-350 CC Lariat 4X4 LB PSD SRW, Heated leather, off road package, western snow plow, strobe lights in parking lights, headlights and backup lights, tinted windows, stull billet insert, pioneer cd player, rockford fosgate 700S amp rocking 3 JL Audio 10W0's behind back seat,Infinity Interiors and an Alpine amp, husky liners front and back,Banks transcommand, K&N FIPK, ATS Ported Turbo Housing, Diablo Sport 110HP chip, Hypermax pryo/boost gauge, Hypermax 3.5 inch downpipe and 5 inch exhaust.
2002 F-350 XL 4X4 PSD DRW, XL Decor Package, 9' Heil Dump Body, 8' Western (for now) Poly Plow, Western Pro-Flo 1, Strobes Front and Back, toolboxes and Wheel Simulators.
Old Dec 6, 2002 | 10:36 AM
coachhomer's Avatar
coachhomer
chips
what are boost and pyro gauges Dave?
scott
Old Dec 6, 2002 | 10:51 AM
Distinctive Dave
chips
>scott
Scott
The boost gauge measures the PSI (pound per square inch of pressure) that the turbo is putting out. Stock trucks get around 18PSI, I get about 25-27PSI with a boost tube. With the wastegate unplugged I can get 30PSI easily. By having a boost gauge you can tell when the air filter is dirty or better yet, i was able to tell that i had an oil leak, because if your low on oil pressure you dont get full boost. You also will want to keep your PSI under 25 to save your turbo.
Pyrometer= EGT'S=Exhaust Gas Tempatures
This is measured most of the time Pre-Turbo on the drivers side at the lowest point of the exhaust manifold. Like its name it measures the temp of the gases. You need to keep your temps under 1200F if you put it pre turbo. The reason for this is that if you go over 1200F you can damage your turbo, valves and othe vital parts in your engine.
Old Dec 6, 2002 | 10:55 AM
goalie's Avatar
goalie
chips
The boost gauge shows psi(pounds per square inch)the turbo is pressurizing the intake and the pyro(exhaust gas temparture) measures the exhaust temps coming from the engine.These guages help to inform you of the idle down time needed for cooling the turbo and for not running the engine into too high of an egt and melting some pistons.
Old Dec 6, 2002 | 12:02 PM
LW555's Avatar
LW555
Post chips
sawz5
Jan 8, 2009 05:24 AM
sgrol
17
Apr 13, 2006 01:06 AM
1995Ford250
Jan 19, 2005 01:48 PM
robertleeii
Feb 3, 2004 03:04 PM
baxter
Computer Chips & Tuners
Oct 16, 2002 09:48 PM
