Dull headlight lenes
Old Apr 11, 2004 | 06:28 AM
68torino's Avatar
68torino
Thumbs up Dull headlight lenes
How to remove the haze from plastic headlight lenes.
I bought a polishing pad and bonnet for my drill and some plastic polish. Total cost around $10. Place some polish on the pad and gently work it onto the headlight lens. Start with a some what firm pressure and as the polishing compound thins out lighten up the pressure to finish polishing. Watch out for the casting nibs, you don't want to catch them and break your headlight lens. It takes about 10 to 15 minutes per side, be sure to touchup the marker lights too. Then give your vehicle a good cleaning to remove compound residue. Then a coat of wax can be applied to the lenes for protection.
Worked great on my son's '90 T-bird.
Old Apr 11, 2004 | 07:43 AM
red mist one's Avatar
red mist one
Also, as a cop, I've seen/used several diferent polishing compounds for plexi/plastic lightbar covers. Try a cop supply place. Good tip 68!
Old Apr 13, 2004 | 05:53 AM
MScotty's Avatar
MScotty
I just used the kit I purchased through Eastwood on my 87 T-Bird.
I was surprise to find that it came with a tube of Autosol metal polish.
But it worked!
After using the buffing wheel/polish I finished up using the Meguaires plastic polish by hand to bring out the brightness.
Old Apr 30, 2004 | 12:40 PM
Trail Rider II's Avatar
Trail Rider II
Sand with 1500 grit wet, then polish
with a sewn flannel wheel in your drill using a plastic polishing compound ACE/True Value Hardware has them.
I did this to my truck, son's truck and the wifes car, looked like new all in just three hours.
The next week took a headlight breaking rock with the truck.
Bought new Diamond clear lens off e-bay for the price on way less than a Ford unit.
The new ones make night driving three times brighter. Dont even need high beams now.
Old May 6, 2004 | 09:11 PM
judge1971's Avatar
judge1971
I did this on my 90 f150 I used 1500 sandpaper wet sand than use 3m glaze compound with a buffer and it will look like new
