Bronco II Ford Bronco II
A Very Small Tip ! 85 B2
Old Apr 11, 2004 | 02:53 AM
warmgravy's Avatar
warmgravy
I don't know if this is common or not.I was installing a foglight switch on the trim with the headlight **** on it. When I went to remove the headlight **** I found that the release button was facing down instead of up. The whole headlight switch/harness was upside down. I had to remove the screws holding the fuse panel in place, slide that out of the way and the release button was right there. I waste about 15 min feeling around on the top which is where the chilton manual depicted it to be. Arrggghhh !
Hope this helps someone else.
Old Apr 11, 2004 | 08:37 AM
GrayRanger4x4's Avatar
GrayRanger4x4
Thanks for the heads-up.I wondre if my 89 is thst way?
