stud gun wanted
Old Apr 11, 2004 | 12:37 AM
F series's Avatar
F series
stud gun wanted
I was just wondering what should I be looking for in the way of a stud gun for a someone who has not been around them much, maybe some good options or name brands and such, THANX
Old Apr 11, 2004 | 04:40 PM
kevin71100's Avatar
kevin71100
Try a personal defense site. I've been thinking of getting one for my potato gun. More power is better to an extent. Try stun batons or stunguns on a search engine.
Old Apr 11, 2004 | 05:22 PM
triton_2002's Avatar
triton_2002
stud or stun
Old Apr 11, 2004 | 06:58 PM
Aekisu's Avatar
Aekisu
<cr>
Wow, this is confusing. Stud, spud, or stun gun. You forgot the spot gun.
I suspect he is referring to a stud welding gun. And if that is the case, the next question is...
Are you talking about the type of stud you use to pull sheetmetal dents or the type that looks like a bolt, without a head?
Old Apr 15, 2004 | 01:09 AM
F series's Avatar
F series
Sorry about the confusion,I was talking about a stud welding gun for pulling dents Where you weld the studs/nails to the metal and then use a slide hammer to pull the dent out.
Old Apr 15, 2004 | 02:49 AM
Aekisu's Avatar
Aekisu
<cr>
Ahhhh, I don't recall the name of the gun I use but it's yellow in color. As if that helps you any.
Personally, if I wasn't using it on a daily basis, I would probably go with the cheapest one I could find. In most cases, for the person that uses it once in a while, the guarantee would be expired before the gun wore out.
Old Apr 15, 2004 | 11:20 AM
uk1050's Avatar
uk1050
You Can Get Cheap Ones Through Harbor Freight With Pins And A Slide Hammer For 100.00. Or More Expensive Ones Through Eastwood. 250-350
I Think Im Going To Try The Harbor Freight Route First. Not Sure What The Difference Would Be. If Anyone Knows I Would Love To Know Before I Buy
Old Apr 16, 2004 | 01:50 PM
kevin71100's Avatar
kevin71100
Stud Gun, well that's very different, nevermind
Sorry but I was the one confused.
