Green knob disconnect
Old Apr 10, 2004 | 09:09 PM
cheinz46's Avatar
cheinz46
Green **** disconnect
I saw an ad for the green **** battery disconnect that had a 15A mini fuse in parellel with the disconnect. With the **** removed from this disconnect, the 15A fuse supplies enough juice to keep lights and accessories functional, but not enough to start the truck. I had a green **** all ready so I just bought a mini fuse holder and installed it. I found a new use for the setup when I replaced the main wiring harness today. Rather than test my workmanship with the green **** connected, I tested it with only the fused bypass. Sure enough, I blew the fuse. I found the short, repaired it and everything worked great. Had I tested the new wiring with the full power of the battery, well, it wouldn't have been pretty.
