low clutch problem
Old Apr 10, 2004 | 07:22 PM
hartattack's Avatar
hartattack
low clutch problem
i just had put in a new clutch and pressure plate for my 86 f150 and also a new slave cylinder. the clutch remains extremely low and practically have to put it throw the floor to change gears. the mechanic said it doesnt have a adjuster nad that the clutch will have a just as long as a life as if it higher. is this the truth? the clutch has always been alittle low, that thats when i couldnt shift it before and they said i needed a new clutch. now i'm thinking that the old clutch may still have been good but just needed adjusting if that can be done. any help out there?
Old Apr 10, 2004 | 07:29 PM
King Triton's Avatar
King Triton
Sounds to me like you might still have some air in the line to the slave cyl,did you get your old clutch disc back?
Bob Ayers's Avatar
Bob Ayers
Your mechanic is correct, a hydraulic clutch is "self" adjusting. If it wasn't properly bled, then it will engauge close to the floor.
Old Apr 11, 2004 | 05:43 AM
hartattack's Avatar
hartattack
will the lkife of the clutch be affected if i leave it the way it is? will it where out quicker??
Old Apr 11, 2004 | 06:40 AM
Bob Ayers's Avatar
Bob Ayers
If it is not dis-engauging fully, then the clutch disc will have excessive wear.
Old Apr 11, 2004 | 06:45 PM
Beast12's Avatar
Beast12
You may also want to look at this thread: https://www.ford-trucks.com/forums/s...d.php?t=224958 or this thread: https://www.ford-trucks.com/forums/s...d.php?t=224958 I have the same problem on my truck but I just leave it. There is a part that needs to be replaced. In the second link, look at Steve83's post. Good luck!
-Matt
Old Apr 11, 2004 | 08:31 PM
utbroncodriver's Avatar
utbroncodriver
i was having the same prob and it was just that a little arm under the dash had slipped just had to take it off and turn it back and it worked great again
Old Apr 11, 2004 | 08:33 PM
utbroncodriver
oh well that is the part i eventually had to change it as well
Old Apr 12, 2004 | 10:14 PM
hartattack's Avatar
hartattack
thanks guys
