Door Lock Argh
Old Apr 9, 2004 | 11:38 PM
Samsonitesamsonite's Avatar
Samsonitesamsonite
Door Lock Argh
Hey the truck in question is in my sig. Anyway, the drivers door lock is acting up.... it lock fine, it unlocks fine also, most of the time. It will unlock if you do not touch the button, once the door button has been depressed, the door will not unlock from the outside, i must go around to the passenger side in order to unlock it. HELP! what could the problem be? and how to i fix it?
Old Apr 10, 2004 | 09:02 AM
cdd5599's Avatar
cdd5599
Ya I have the same problem so if somebody knows please share the answer.
chuck
Old Apr 10, 2004 | 08:56 PM
35l911's Avatar
35l911
i don't have the same problem but my 84 just had the drivers door lock replaced because my sister lost the door keys but if some body pushes the button to get in the truck (not electronic locks here all omish) the key will not work intil you beat around the lock i like that so nobody steals my truck or my brand new 35 doller am/fm/tape radio LOL
Old Apr 10, 2004 | 10:01 PM
Samsonitesamsonite
haha, i just dont like having to get in on the passenger side, a lil emabrrassing on dates jk
Old Apr 11, 2004 | 09:14 AM
dmuncy's Avatar
dmuncy
a little wd 40 works wonders
Old Apr 11, 2004 | 09:49 AM
Samsonitesamsonite
tried it, doesn't help, i need to know whats wrong guys! help!
Old Apr 11, 2004 | 01:22 PM
speedwheeler's Avatar
speedwheeler
take the inner molding stuff off the inside of the door and look at all the rods and stuffcheck for binding or bent rods or un hooked stuff play around with it and watch how stuff works thats how i do it when my stuff dont work
Old Apr 11, 2004 | 01:24 PM
speedwheeler
Old Apr 11, 2004 | 06:27 PM
Samsonitesamsonite
thanks ill try it out
Old Apr 13, 2004 | 02:56 AM
locknkey's Avatar
locknkey
Lock linkage rod is going down too far creating a bind possibly dued to near broken clip or clip stripped out/off.
Old Apr 13, 2004 | 04:02 PM
Samsonitesamsonite
thanks ill check that out, hopefully thats the prob
Old Apr 19, 2004 | 05:11 PM
toml98's Avatar
toml98
My truck has the same problem. Basically what is happening is that over the years, the door key becomes worn as well as the tumblers in the lock. Eventually the two don't match up as well as you'd like them to and it begins to create this problem. Since the passengers door is not unlocked by key as often, the tumblers say in much better condition, allowing the worn key to operate correctly. If you pull your door panel off and look at the lock itself, somewhere on the lock body you'll find a code, this is the tumbler code. You should be able to take this code to a locksmith and have a key made that would perfectly match the original key in new condition. (At least this is what I've been told, but havent' tried it) Hope this helps
Old Mar 23, 2005 | 03:14 AM
bill1958's Avatar
bill1958
Listen to locknkey; he's got your fix. LOL and don't worry kid, if she really loves you, she won't care what side of the truck you get in; and if she complains, tell her to walk HA HA HA
Old Mar 24, 2005 | 02:06 PM
Samsonitesamsonite
thanks man but that truck got totalled
