Diesel numbers
Old Dec 9, 2002 | 08:54 AM
rabidranger's Avatar
rabidranger
Diesel numbers
Since I am new to this forum I am sure this question has been asked a 1000 times, but...
What are the HP and torque numbers for the:
7.3 Powerstroke
6.0 powerstroke
Chevy Duramax
Dodge Cummins
Just need to settle a debate....
Also which is better (honestly, not just cuz it's ford) but the new torque flight, or the chevy allison?
Old Dec 9, 2002 | 02:59 PM
DCSpecial's Avatar
DCSpecial
Diesel numbers
[updated:LAST EDITED ON 09-Dec-02 AT 04:15 PM (EST)]>Since I am new to this forum I am sure this question has
>7.3 Powerstroke
2002 with auto had 250hp 525lb/ft
>6.0 powerstroke
325hp and 560lb/ft
>Chevy Duramax
not sure I think 300hp and 520 lb/ft
>Dodge Cummins
The new high output cummins is 305hp and 555lb/ft
Torqshift: smooth shifts, tow/haul mode and it communicates with the new engine to provide you with compression braking. Also ford claims it is built to last 250,000 miles along with the new 6.0L
Old Dec 10, 2002 | 06:06 AM
rabidranger
Diesel numbers
Thanks! I knew the 6.0 trounced the Duramax.
Old Dec 10, 2002 | 07:04 PM
PwerStroke99's Avatar
PwerStroke99
Diesel numbers
Go with the 6.0. The numbers wont lie!!!! i hear it is an amazing engine!!!!
Old Dec 11, 2002 | 10:05 AM
ehagerty's Avatar
ehagerty
Diesel numbers
So then if I do the #'s if you invest $350 in a supertuner then your running 310/640 or(620) depending on the yr. Makes my 7.3 look good still
Old Dec 11, 2002 | 11:20 AM
Gwilkrrs's Avatar
Gwilkrrs
Diesel numbers
