Heater location
Old Apr 9, 2004 | 05:51 PM
kevin69's Avatar
kevin69
Heater location
I have a 1950 F-1 with the heater in the middle under the dash. Is this the right location or was this added aftermarket?
Old Apr 9, 2004 | 06:49 PM
tlb's Avatar
tlb
Hi Kevin
I have a 48 F1 and the heater on mine is located on passenger side under glove box.
Not sure if this is correct but it looks like it is.
Terry
Old Apr 9, 2004 | 07:36 PM
barry's Avatar
barry
The correct location is under the passenger side. There are 2 type of heaters Ford put in. THe first used the air in the cab and was called the recirculating heater. All it had was just the 2 hoses from the engine going to it. The second was the "Fresh aire" heater. THis had a air duct coming in from the passenger side kick panel that fed the heater. It got the air from a tube and duct assy that was above the tire and bolted above the headlamp to pick up fresh air. It also had a water temp valve that bolted to the firewall above the heater. If you look at your firewall inside the engine compartment, you'll see the knockouts for it. The control had 3 cables as the recirculating had only 2. Your heater is a aftermarket. THis was very common. Sears, J.C. Whitney, Montgomery Ward and others all offered heater kits to install. These were usually cheaper than Ford, so many opted for these instead. That's why you see so many with oddball looking heaters in them. The factory heaters come up on Ebay now and then. You just have to keep looking. The Ford shop manual has excellent diagragms of the heater set ups.
Barry
50 F-1
Old Apr 13, 2004 | 09:24 AM
kevin69's Avatar
kevin69
Thanks for the information. It is very important that I know this. I am trying to put it back to factory condition. Thanks again.
Old Apr 13, 2004 | 09:29 AM
kevin69's Avatar
kevin69
