battery drain and more,
Old Apr 9, 2004 | 12:58 PM
frankeb's Avatar
frankeb
Exclamation battery drain and more,
I have a 92 F-150 xlt. Everytime I connect the battery the lights come on even with the switch off, so I removed the head light switch and it still happens. Even with the ignition switch off it does it. Also it sounds like its running a pump in the transmission so I unplugged the wires to the tranny to trouble shoot before it ran the battery down. I have seen no coroded wires or any exposed wires grounding out. I have about disassembled the entire truck to find the problem.
I have went through all the fuses but to no avail.
So I decided to come here and ask for help. Hope I'm in the right place.
Frankeb
Old Apr 9, 2004 | 01:07 PM
King Triton's Avatar
King Triton
It sounds like you may have a fusable link problem,or some sort of power distribition problem,I would try and remove the secondary wires from the starter relay,and check and see if possibly 1 has melted into the other,certain circuits do not feed through the ign switch so key on or off wont help you.
Old Apr 9, 2004 | 01:18 PM
Mil1ion's Avatar
Mil1ion
Are they the brights or normal lights ?
Old Apr 9, 2004 | 01:20 PM
frankeb's Avatar
frankeb
i'll check on this and find out which lights and i'll unhook the starter, brb and thanks for the quick response,
Old Apr 9, 2004 | 01:48 PM
frankeb's Avatar
frankeb
good news, dummy me didnt notice hazard switch was on so lights back to normal, now to figure out the humming noise in tranny when power is connected, i get an ERROR.3 in odometer when switch is on , will not turn over with switch or crossing the solenoid
