Offroad & 4x4
rockwells question
Old Apr 9, 2004 | 12:42 AM
88bronco351's Avatar
88bronco351
rockwells question
who actually makes rockwells I've seen gmc 2 1/2 ton is this the same thing
Old Apr 9, 2004 | 12:47 AM
fishmanndotcom's Avatar
fishmanndotcom
ROCKWELL
http://www.rockwellautomation.com/about_us/history.html
-jason-
Old Apr 9, 2004 | 09:02 AM
bremen242's Avatar
bremen242
GMC 2.5tons are frontloaded, like the older eaton axles that came under some old GMC pickups. Rockwell are top loaded with a third member. GMC axles look like a normal axle, except huge. Rockwells are weird looking (for an axle). They have square tubes.
Old Apr 9, 2004 | 09:51 AM
ivanribic's Avatar
ivanribic
Top loaders equate to better drive shaft angles not to speak of safer drive shafts being up high. I'm not sure what the specs are on the GM axles but the one disadvantage to the Rockwells is you only have 1 gear ratio available . . . so you better run a BIG tire unless you just don't plan on getting much speed out of it.
Old Apr 9, 2004 | 12:34 PM
proeliator's Avatar
proeliator
Rockies are great. Don't much care for the gmc deuces. The rocks gr is 6.72 btw. Yea, don't think you'll running down the freeway on 35s with those
Old Apr 9, 2004 | 02:00 PM
moose94's Avatar
moose94
maybe...........
Old Apr 9, 2004 | 03:09 PM
buzziscrazy2's Avatar
buzziscrazy2
Just a side note, Dana 60's have stronger shafts..........if you plan on being hard on you vehicle and running 48's or bigger, you might want to think about 5 ton clarks.........much bigger axle shafts and less prone to breakage.
Old Apr 9, 2004 | 03:23 PM
rlh's Avatar
rlh
Stick a Warn OverDrive in there and cruise 'er at 70mph . . .
Old Apr 9, 2004 | 03:53 PM
fishmanndotcom
they are stronger but due to their extreme weight it really isn't worth it! i have been trying to figure out how I can get 5 ton shafts in 2.5 ton housing.
-jason-
Old Apr 10, 2004 | 01:09 AM
Momudder720's Avatar
Momudder720
I was doing some chatting with my neighbor who has run both rockies and Eaton deuces, and he likes the Eaton's more because they don't require as much power to get everything started moving. In all honesty, I've never tried to turn the driveshaft of either one, but that would make sense, since the rockie is a double reduction and the eaton is a single reduction. True, the driveshaft angle would suffer a bit, but when you're talking muddin' and jumpin' in a tube frame buggy and not rockcrawling, I don't see where there would be any driveline issues. I know what you're gonna say, and that less of an angle is always better regardless of what you're doing, but he feels that it's worth the tradeoff to run a less-torque-hungry axle.
Old Apr 10, 2004 | 01:07 PM
proeliator's Avatar
proeliator
Thats actually a good point Mo'. Personally, I'd still stick with the rockies but it would sure be interesting to see actual numbers on how much power the the rockies eat over eatons due to the double reduction.
Old Apr 12, 2004 | 10:41 AM
Momudder720
What I can do is get a torque wrench and somehow attach it to the yoke on each of them and see what the measurement comes out to. I might do that in me free time (ha!) this week...
Old Apr 12, 2004 | 03:09 PM
fishmanndotcom
Arrow
ok i have sat here and not said anything for too long and it is killing me i gotta say it... then why do they call D60 1 ton equipment and rockwells 2.5 ton? hmmm, lol. is that why deuce and a halfs run 50" michlins b/c the rockwells are too weak? i guess they better upgrade to D60's....hell go stronger and get a D30/ford 8.8! THAT is where it is fellas....D30/ford 8.8, screw rockwells!
-jason-
Old Apr 12, 2004 | 04:37 PM
ivanribic's Avatar
ivanribic
Makes you wonder, doesn't it Jason? I thought there was a reason people were getting rid of the Dana 60s and going to rockwells . . . maybe not. I would be curious to hear the torque specs on what it takes to turn them compared to a GM axle. All that gearing has got to eat up power somewhere but I suppose that's what big blocks are for.
Hey, one more question. I want to buy a fishing boat. Do I need a big engine or do you think I'd get by okay with a TROLLing motor?
Old Apr 12, 2004 | 04:50 PM
fishmanndotcom
depends on the lake I fish all the time at Lake Horton here and it is a non-hydrocarbon fuels lake (no gas or diesel!) just electric motors and sail boats and rowboats. i like it cause there is no wake or jet skis to compete with. but it takes FOREVER to get from one side to another....in fact i take 3 fully charged batteries with me and they all end up being drained. maybe it's my bling stereo, fridge, trolling motor, and lights that drains it
-jason-
yes Ivan, i know you were joking
