how to sand the tape
A body shop will sell you a rubber tired wheel that will take the tape off. I think youll find they want it run at a high rpm. I used it and a plastic fork from wendys modified some what to scrap it off. The tape gets brick hard after sun and time. The fork is cheaper but won't scratch the finish. It will take some time, go slow.
I did a lot of car decal work in the past and we always worked with a hairdryer. the trick is: you really need to have a lot of patiance. work slowly. warm it up take some of it off and warm it up again.
i'm going to do it also (on our BII there is also some fine old dryed out hardened decaltape wich defenetly must come off ) we will not mind some paint damage, because that is part of the project, it going to be in a other color.
