break pedal shake?
Old Dec 18, 2002 | 09:38 PM
Starratt04's Avatar
Starratt04
break pedal shake?
i have a 99 f-250 4x4 psd.when i start up my truck and its idle the break pedal vibrates. when i get up to around 40-45 and higher and i hit the breaks it dosent shake but once i get below 40 or around there its shakes. my break pads and new and i had my rotors turned less that 2k miles ago. what could be the problem?
Old Dec 19, 2002 | 06:33 AM
79CEEJAY's Avatar
79CEEJAY
break pedal shake?
[updated:LAST EDITED ON 19-Dec-02 AT 07:34 AM (EST)]I would double check the rotors. I once had a set turned and they shook right away. The next day I took them back to the shop that did them and they guy asked where I had them turned. I said right here. He chucked them up on the lathe and said they were not true. He recut them and they were fine. It is possible thet whoever cut them did not have them chucked up in the lathe properly and the rotor is cut inproperly. This might be your problem since they appeared to be ok before your brake job. Also, just for laughs, How are the front wheel bearings? Are they tight and greased properly? This can also cause a shake that resembles warped rotors.
Old Dec 19, 2002 | 06:57 AM
FortyFords's Avatar
FortyFords
break pedal shake?
Wait ! your post says it shakes at Idle! are you moving? or parked?
Ceejay! I know what your getting at rotor warp !
His post led me to believe he was parked.
But I'm not sure now!
Rich
:-X12
02 F250 4x4 SC 5.4v8 6spd 3.73ls Trueblue/Silver and Chrome Nerfs
"All Levers"
Old Dec 19, 2002 | 10:33 AM
Starratt04's Avatar
Starratt04
break pedal shake?
yea if im in park it vibrates and then when i switch in drive or reverse the same vibration. but it seems when im over 40mph and hit the breaks no vibrate. but once it gets under 40 its seems to vibrate
Old Dec 19, 2002 | 09:20 PM
FortyFords's Avatar
FortyFords
break pedal shake?
You might have a problem with your abs unit!
When it does this does it feel like pulsations ,another words if you just lightly touch the brake pedal with your foot can you feel little vibrations?
When you first start your truck does the abs light come on and then go off? If not the bulb could be bad or the abs unit is not doing its self test mode therefore something is wrong in the unit.
You also could just have a bushing problem in the pedal !
Hope this helps
Rich
"All Levers"
Old Dec 19, 2002 | 10:03 PM
Starratt04's Avatar
Starratt04
break pedal shake?
yea it does vibrate and my abd light comes on and then goes off. it almost feels like its the vibration off the engine cause when its in overdrive it dosent shake but when its not in over drive it does shake
Old Dec 20, 2002 | 07:54 AM
jschira's Avatar
jschira
break pedal shake?
Lariatpower04
2004 - 2008 F150
Aug 28, 2010 12:02 AM
bajaford
Dec 5, 2007 07:29 PM
jrtaylor
1997 - 2003 F150
29
Dec 16, 2006 03:52 PM
joeford150
New Hampshire Chapter
Jul 27, 2004 04:28 AM
akerstrom
Feb 10, 2004 06:16 PM
