what determines fuel requirments?
Old Apr 8, 2004 | 12:33 PM
dieingford's Avatar
dieingford
Is the compression ratio the only thing that determines what octane fuel you have to put in? In other words all other things the same could a 14:1 motor run on pump gas if the pistons where switched to like 9:1 pistons?
Old Apr 8, 2004 | 04:14 PM
Mike G's Avatar
Mike G
Wouldn't that take all the fun out of it?
Old Apr 8, 2004 | 05:32 PM
3eggOmelet's Avatar
3eggOmelet
compression and timing are the only things that matter.
Old Apr 10, 2004 | 08:01 AM
71swissaqua's Avatar
71swissaqua
i think you have to consider other things as well, such as the amount of quench you have, type of head, aluminum heads can usually handle more compression without detination
Clint
