1984 Specifications
Old Apr 7, 2004 | 11:19 PM
blksmith's Avatar
blksmith
1984 Specifications
Just bought a 84 F-250 6.9 diesal , and am trying to find the breakdown for the code numbers so I can figure out what tranny and rear end it has. Thanks for any info.
Old Apr 8, 2004 | 11:00 AM
sail2244's Avatar
sail2244
I have the spec book so if you give me the codes you are looking for i will look them up for you. They are on the tag on the drivers door post
Old Apr 8, 2004 | 10:46 PM
blksmith's Avatar
blksmith
The tag list the TRANS as "K", the AXLE as "G3" and the SPRING as "KK".
What I am trying to figure out is if the truck is low geared as I was told, since at about 65 mph it sounds like it needs another gear.
Thanks for the help.
Old Apr 8, 2004 | 11:00 PM
82F100SWB's Avatar
82F100SWB
You have a C6 auto with 3.54 gears, rear end is a 6300 LB limited slip Dana, I'd assume a D60 with that rating. Should turn around 2500 at 65 mph, just like my 460 powered beast, it too needs another gear.
Old Apr 8, 2004 | 11:34 PM
blksmith's Avatar
blksmith
Thank you for the quick information! That solves the major worry I had about the truck
