drivetrain noise...
Old Apr 7, 2004 | 09:25 PM
FasstR88's Avatar
FasstR88
drivetrain noise...
ok when you go full throttle from a stop my 94 f150 makes a loud clunk i looked in under at the driveshaft and everything seems fine but the bushing that the driveshaft runs through seems to be loose, do you think this is the problem?
Old Apr 7, 2004 | 10:19 PM
FordPerf300's Avatar
FordPerf300
carrier bearing? most likely thats the culprit.
Old Apr 7, 2004 | 10:20 PM
c96drumm's Avatar
c96drumm
Last time I had a clunk like that, it was u-joints. Couldn't detect any play in 'em by hand, but the clunk was gone after replacement.
Old Apr 7, 2004 | 11:27 PM
fordberg's Avatar
fordberg
When I had the carrier bearing go out there was a vibration while driving. There is a lot of torque transmitted in the drivelive, a clunk from the carrier bearing seems reasonable. I have found that u-joints click when they get dry. It could be that a u-joint seizing would make the carrier bearing slap to one side.
Old Apr 7, 2004 | 11:54 PM
FasstR88's Avatar
FasstR88
yes the busing i was reffering to is the carrier bearing... i didn't know the exact name of it at the time.
