Sponsored by: Kumho
E150 brake problem
Old Apr 7, 2004 | 06:35 PM
grmjr's Avatar
grmjr
E150 brake problem
I have a 2001 E150 cargo van (50k miles) that has grinding and heavy pulsing when the front brakes are applied. I have replaced the pads (3x), rotors (2x), calipers (1x) and the problem comes back after only a couple of weeks. When I hit the brakes at about 45 mph the steering wheel vibrates and pulses rapidly making it hard to handle. It is almost like the brakes are not releasing. The van is lightly loaded. Someone told me it could be the booster. I took it to the dealership to be analyzed with no luck.
Any ideas?
Thanks
Old Apr 8, 2004 | 09:32 PM
KYHossF150's Avatar
KYHossF150
Are you using good pads, or the Carquest specials? Not all pads are created equal. I assume your fluid is full, and all has been properly bled. At 50K, I should hope your master cylinder isn't the problem, but that's about all that's left to check, unless you've got a kink in the lines or something.
