Squeeling noise
Old Apr 6, 2004 | 05:40 PM
660grizzman's Avatar
660grizzman
Squeeling noise
Does anyone have an answer for me? My dealer doesn't. After the engine is hot from driving, I get a sound like a belt squeeling. It happens over 70 mph. I can just be driving normal and it will start. If I kick the a/c on it will go away for a couple seconds and then come back.
Old Apr 6, 2004 | 05:43 PM
johnsdiesel's Avatar
johnsdiesel
Bent pulley? Check them all to make sure they aren't loose. You might need to replace 1 or more.
Old Apr 6, 2004 | 05:47 PM
660grizzman
The dealer said they check all of them
Old Apr 7, 2004 | 01:20 AM
lymant's Avatar
lymant
it maybe possible that the bearing on the ac pulley is going bad, when the ac is running the clutch locks the ac and pulley together and after a short time the ac cycles releasing the clutch. ac pulley rides on bearing.
Old Apr 7, 2004 | 07:50 AM
660grizzman
Thanks, I'll mention it to them.
