Spark Plugs
Old Apr 6, 2004 | 01:30 PM
JojoManigbas's Avatar
JojoManigbas
Spark Plugs
Hi,
I've been researching for the best replacement spark plugs for my 95 Explorer 4.0L 4wd. The results were that Motorcraft ASWF-42PP works the best. Not able to find the plugs in stock at my local auto supply store, I went to a Ford Dealer. They also did NOT have the ASWF-42PP in stock, he recommended Motorcraft AGSF-42FMF6.
Has anyone out there use(d) AGSFM-42FMF6 on their explorer?
Do you recomment these plugs?
Thanks in advance,
Jojo
Old Apr 6, 2004 | 08:26 PM
nhfire 77's Avatar
nhfire 77
Bosch is the same product line so just go to Autozone (or any parts store and get the OEM equilivent of the bosch brand--I think they are the double platinum-worked for me) and a ford dealer will Take your wallet over the coals
Old Apr 6, 2004 | 08:27 PM
nhfire 77's Avatar
nhfire 77
Old Apr 6, 2004 | 10:01 PM
87 XLT's Avatar
87 XLT
I agree, I change the Bosch single electrode plats in my 87 2.9 & 95 3.0 every 90 K. They always look so good, im tempted to leave them in longer. I see NGK now has irridium plugs on their web site. Less money & supposedly better than the platinums.
Old Apr 6, 2004 | 10:11 PM
CobraXP's Avatar
CobraXP
I actually have a set in my garage. They will be going in this weekend when I get done with the cam swap. I'll let you know how they do after a test run...
Old Apr 7, 2004 | 01:46 AM
87 XLT's Avatar
87 XLT
It will be interesting to see how they work for you. Theres a thread at the Hyundai cnnection on this. A guy was asking if the NGK V-groove would be the best bet for better MPG in his 4 banger Elantra. Duke/the moderator & a tech at a dealership in Canada had this to say: "The V-groove does not give you a double spark, it merely ensures a clear spark launch point if one tip is somewhat contaminated. We now install the newly available NGK iridium plug, which withstands higher combustion temp, ignites a leaner mixture better than platinum, and is cheaper with a longer life span." Sounds pretty good.
Old Apr 7, 2004 | 10:33 AM
CobraXP's Avatar
CobraXP
I've had them for about a year now. I bought them when I ordered my plugs for my jet skis and boats (I buy them in bulk). I saw them on their site then, and thought I would try them. They have been sitting in the garage ever since.
Old Apr 7, 2004 | 11:18 AM
Bob Ayers's Avatar
Bob Ayers
Whatever you do, stay away from Bosch, they DO NOT run well with Ford's EDIS!!!! The AGSF42FMF6 is Motorcraft's new "fine wire" platinum plug. I am running these in my
3.0L Ranger now, and they run well!!!!! This is the very
best plug for your 4.0L!!!
Old Apr 7, 2004 | 12:37 PM
jwirth's Avatar
jwirth
FWIW AGSF42FM @ rockauto.com $3.35 ea.
Old Apr 8, 2004 | 10:00 AM
99Xplr's Avatar
99Xplr
Bob.... what sort of problems did you see with the Bosch plugs. I just installed a set this weekend and now that I see this I'm starting to think that was a mistake.
Old Apr 8, 2004 | 10:12 AM
Bob Ayers's Avatar
Bob Ayers
I think there is a heat range problem with the Bosch. I have a 3.0L FFV Ranger, that the previous owner had installed Bosch (at only 36K miles), and it developed a real
bad mis, when under load at a low RPM. I replaced the Bosch with Motorcrafts, and this cured the mis problem.
All I use in my gasoline Mercedes is Bosch, and they run great!!! But I only use Motorcrafts in my Fords!!!!!
Old Apr 8, 2004 | 10:15 AM
99Xplr's Avatar
99Xplr
Thanks for the info... I guess I'll just keep an eye on it for now. If it becomes a problem then out they come.
Old Apr 8, 2004 | 11:43 AM
jwirth's Avatar
jwirth
Are there any local places like Fisher Auto Parts or NAPA that carry Motorcraft?
Old Apr 8, 2004 | 01:24 PM
nhfire 77's Avatar
nhfire 77
Bosch and MotorCraft are made in the same factory, using the same materials--So you had a bad plug. Motorcraft are sold by the dealers and some parts distributors, or they have the OEM equilivant which would be Bosch.
Old Apr 8, 2004 | 02:39 PM
Bob Ayers's Avatar
Bob Ayers
NOT TRUE!!!!
Motorcraft and Autolite are both made by Honeywell, a division of Allied Signal.....
