what is a 351h
Old Apr 6, 2004 | 11:58 AM
nucleartruck's Avatar
nucleartruck
what is a 351h
I have a 78 f250. I ran the vin and noticed I have a 351h engine. What is it? Also, it has a np435 trans - can I use this trans on my 79 f250 w460 cid?
Old Apr 6, 2004 | 12:22 PM
snowfighter's Avatar
snowfighter
The trans will swap, I've never heard of a 351h I have seen a 351w a 351c a 351m and a 351ho.
Old Apr 6, 2004 | 12:51 PM
Ironeagle's Avatar
Ironeagle
The "H" is a designator for a 2BBL Carb with provision for an evaporator canistor. (Emmisions Carb).
Old Apr 6, 2004 | 01:18 PM
F150daniel's Avatar
F150daniel
your 78 F250 came with a 351M 2bbl stock. yes you can use that tranny with a 460.
Old Apr 6, 2004 | 03:34 PM
Torque1st's Avatar
Torque1st
Posting Legend
You will need to make internal changes to the transmission in order to make a 351M C6 live behind a 460. It will bolt up but the shift points, pressures, and clutch packs, etc will be wrong. Check with the transmission forum or your local transmission shop.
Old Apr 6, 2004 | 07:09 PM
Mil1ion's Avatar
Mil1ion
The Letter H is the code for a 351.
Depending on the year of truck or van it could be a 351M or a 351W.
In which case you would havea 351M
the 2 are completely different engines
