Dana 70 questyons
Old Apr 6, 2004 | 05:42 AM
Alsroadster's Avatar
Alsroadster
Dana 70 questyons
hi all! I'm thinking about swapping a D 70 into the rear of my 77 F-250 4x4. The 70 I have is out of a 79 E-350 ex ambulance with the 4:10 that I need and a power-lok. One option is to have one axle and tube shortened for the correct offset, or i thought I might try and find a pickup housing and axles. The 70 I have I think is designated a 70B. Those guts will fit any 70 housing won't they, and what years and models would i look for to find the housing I need? 70's F-350? Dodge? Thanks!
Old Apr 7, 2004 | 06:03 PM
Indybroncoman's Avatar
Indybroncoman
Unless F250 and F350 frames are the same width (which I doubt) you will, at a minimum, have to move your axle perches. Are you really sure that you need a Dana 70? They're strong axles for sure, but there's a reason why not many people run them. Limited gear selection, limited locker options, and reduced clearance being three of them. Plus, a 60 can be made stronger for not a lot of money.
Old Apr 8, 2004 | 11:15 AM
Alsroadster
I don't necessarily "need " it but the 70 I have is paid for and has the right gearing and the powerlock
