Rear Pumkin
Old Apr 6, 2004 | 02:36 AM
coplin's Avatar
coplin
Question Rear Pumkin
Rear Punkin What is the electrical connection that runs into the the top-centre of the rear diff on a 1988 F-150? Couldn't see how it would be ABS although I'm new to Fords thanks
Old Apr 6, 2004 | 04:48 AM
PatsPOS's Avatar
PatsPOS
It is indeed the plug for the rear ABS sensor. Inside the rearend there's a toothed ring sandwiched between the ring gear and the differential itself, and a sensor goes through the top of the carrier to measure the pulses.
Kind of a crude explanation, but someone else can probably explain it better than I can...
Pat
Old Apr 6, 2004 | 10:06 AM
LoosMaster's Avatar
LoosMaster
Explanation is correct. The ABS uses this signal to interpet any changes in wheel speed to prevent lock-up of the rear wheels. The ring is called the "tone ring".
Old Apr 6, 2004 | 10:24 AM
fordberg's Avatar
fordberg
If I have this sensor then do I have ABS? I believe this is the speedo sensor also. I'm curious because sometimes I have slight brake jerk when I take off.
Old Apr 6, 2004 | 01:23 PM
LoosMaster's Avatar
LoosMaster
You do have the ABS. I'm pretty sure it has nothing to do with speed other than controlling the proportioning valve and the RABS. Your speed is taken from the rear of the tranny. The jerk could be coming from the RABS unit or the valve. You need to pull the codes and see if you have any.
Old Apr 6, 2004 | 04:07 PM
coplin's Avatar
coplin
Any special oil required for this diff(its a non-posi unit)Does it need something Ford specific or Can I use regular 'ol 80W90?
Old Apr 6, 2004 | 04:32 PM
LoosMaster's Avatar
LoosMaster
80W90 would be fine. I run Lucas 90w120 due to the heat down here.
