clutch/starter probs
Old Apr 5, 2004 | 01:21 PM
jarrett88's Avatar
jarrett88
ok, finally got the money to fix my truck
86 f-250 6.9 diesel
clutch and starter went out around the same time.
anything else i should do besides just change them out i.e. resurface flywheel?
Old Apr 5, 2004 | 07:25 PM
bigreave's Avatar
bigreave
I would make sure your slave clynder, Clutch master clynder are good and change the tranny fluid check u joints pinnon nut etc .while you have it down
Old Apr 5, 2004 | 11:12 PM
DanMan7's Avatar
DanMan7
Yeah I started hearing a slight shuttering sound when I start my truck now after it's been sitting for awhile. I might have to replace my clutch soon. I'm going to try greasing the throwout bearing tomorrow to see if that solves the problem. I'm also putting in a new starter and battery because it's not starting as easily as it used to.
Old Apr 7, 2004 | 06:14 PM
jarrett88's Avatar
jarrett88
hey dan, also, see if your wires are rotted, because we changed those and the batteries a long time ago, and it helped it alot. and thanks for the info
hopefully im gettin my own truck soon though a 71 f-100 w/ 390 6-inch total lift, 35's and other goodies
the truck i am fixing is my dads
Old Apr 7, 2004 | 08:31 PM
DanMan7's Avatar
DanMan7
I put in the new starter and the shuttering sound is gone. Guess my old starter was almost on its last leg.
