i have a 2000 f-350 crew psd, every now and then my overdrive button blinks,
cruise wont work and everything stays on even when i shut the key off and exit the truck. I also hear a relay type sound from the dash board some where
when I shut the truck off.
I do have a remote starter-if that makes any difference-I have replace the trnsmission sensor and that did nothing..any suggestions would help.
thanks, NBFC
Sounds like your speed sensor (top of rear diff.) is on the fritz. Time for a new one ($20 part at dealer.) If you don't want to spring for a new one, try removing it and cleaning any debris off then reinstall.
