Starting Problems
Old Apr 5, 2004 | 06:56 AM
djpippyc's Avatar
djpippyc
Starting Problems
I know you have probly heard this story before. I own a 1990 e350 that has the 7.3 diesel. If the van has set for a few hours it wil start and run for a second and then die. I have to crank it until the batteries are almost dead (2 x 1000 CCA) and then it will finally fire off and run perfect. If it is started after running for a while it will start perfectly . I have mentioned it to a local mechanic and he said that it should have a fuel pump that helps push the fuel up to the injection pump. He said that the injection pump is not built to suck the fuel all the way from the two tanks just to pressurize the fuel for the injectors. Sounds like a good explaination but is he right??? I really don't want to spend several hundred dollers for a shop to work on it when I can do it myself, so I figured I would get some ideas. Oh Yeah, the glow plugs are working great so I have ruled them out. Any Ideas???
