how much would it be
Old Apr 4, 2004 | 11:10 PM
Ben88f150's Avatar
Ben88f150
how much you think it would be to get true duel exaust from exaust manifold and back includind installation. if ouve done it or just know the price it would be apreciated if you said
Old Apr 6, 2004 | 10:58 AM
94F150-408's Avatar
94F150-408
Ben, it depends on the rates in your area. Call around to some different shops and see what they are charging. There are a lot of variables too. You can get a mandrel bent(best) system. You can get all your pipe in an aluminized version, this helps prevent rust. You can get stainless steel(best against rust). Then you have your choice of mufflers and if your going to use high flow catalytic converters. If your running this on a 88,you probably cant switch over to a true dual. Do you have smog checks in Missouri? You'll need to deceide what all you want with your exhaust system and then do price comparasions.
Old Apr 10, 2004 | 12:13 AM
Ben88f150's Avatar
Ben88f150
thank you for your help. man to tell you the truth i just want it to sound cool and be true duel but hey im a kid what do you expect. but yeah thanks for your advice
