best exhuast??
Old 04-04-2004, 09:11 PM
big6daddy's Avatar
big6daddy
big6daddy is offline
Arrow best exhuast??
im lookin for a good throaty sounding exhaust system for my ride... ive been told flowmaster is the best for this but i was wandering if anyone has any suggestions about a flowtech system or any other system that would accomplish this... any help is appreciated
Old 04-05-2004, 02:06 PM
nastruk95's Avatar
nastruk95
nastruk95 is offline
I've tried quite a few and know allot of peopel that have used other brands, but when it comes down to it for a good sound and loudness the flowmaster 40 series sounds best. If I id mine again I would try going with the one chamber race muffler they have. Gibson sounds good too, but is more quiet, I would stay away from glasspacks they dont sound good unless you removed both cats.
Old 04-06-2004, 01:11 AM
buldozr1's Avatar
buldozr1
buldozr1 is offline
I had sidepipes on my truck when I still had my 300-6. It sounded like a tractor cause I had removed the cats and had run straight pipe into two blown out glasspacks. The guys in the parking lot saw a flame shoot out one time, I wished I could have seen it. A buddy has a 4.2L V6 in his 97 pickup, his 40 series flowmaster was much deeper and sounded a lot better than my sidepipes, and his were dumped with his stock cats in place! I wouldnt pay good money for these bolt on exhuast kits, a reputable muffler shop is the best thing. Good luck.
dozr
Old 04-06-2004, 03:06 AM
Budly's Avatar
Budly
Budly is offline
Cut off the cats. Run 1.5" duals out the back under your bumper into sum HUGE echo cans. Sounds grizzly until about 2500 RPM then it gets a little higher pitched but nothing to bad. I did it and loved it. Loudest pickup i have ever heard.
Old 04-06-2004, 08:17 AM
SPROCKET's Avatar
SPROCKET
SPROCKET is offline
In my opinion Flowmasters suck on 6 cylinders....I had a Flowmaster 40 original and it sounded like crap, had it on for 2 months then I switched to the Gibson SuperTruck exhaust and couldn't be happier since it now sounds like a truck again.
Old 04-06-2004, 09:50 AM
jessfactor's Avatar
jessfactor
jessfactor is offline
cutting off the cats and running glasspacks isn't very good advise. it may work down in hicksville, but some parts of the country have imissions inspections and actually care about the environment. i think there is a sticky in the exhaust forum about this. do everybody a favor and keep the cats on there. think of another way to get a nice sound. its good to use your head every once and a while.
Old 04-06-2004, 10:13 PM
lowrange211's Avatar
lowrange211
lowrange211 is offline
i had both cats removed, and had one high flow installed with a glasspack and in my opinion it sounds pretty damn good. this was on a 84 bronco just to had.
Old 04-07-2004, 12:42 AM
nick88f150's Avatar
nick88f150
nick88f150 is offline
will it make much of a differnce if i leave one cat on? then run a glasspack
Old 04-07-2004, 12:53 AM
Budly's Avatar
Budly
Budly is offline
It will get a little louder but not much, i wouldnt even screw w/ a glasspack. If you can get around emissions like i can here in "hicksville" (queer) cut em off altogether, best sound you can hope for if you want deep, and loud
Old 04-07-2004, 06:10 PM
Fuelinjector06's Avatar
Fuelinjector06
Fuelinjector06 is offline
hey man i have flowmasters on my inline six and i love how it sounds but it wasn't loud enough for me so i got the converter taken off...if i were u i would just get it all done at the same price, it might cost less
Old 04-08-2004, 10:00 PM
MontanaFord's Avatar
MontanaFord
MontanaFord is offline
as my truck sits now (how it was when i acquired it) is a single 2 1/4" pipe, no cats, into a 30" glasspack...it sounds alright...semi-deep packy "rumble" if you will, but as for flat out loudness...ain't good enough for me...i'll probably give a 20-24" pack a try, down the road, and if i don't like that, i'll give a 40 series flow a shot...
for the truck i'm planning to build up, i'm gonna run true dual 2 1/4" pipes into a pair of 40 series flows w/ turn-downs just ahead of the rear axle housing, to dump the sound into the pavement and then out....thinkin it should sound pretty good...we'll see when it happens...
MontanaFord
Old 04-10-2004, 01:49 PM
Blue89F150's Avatar
Blue89F150
Blue89F150 is offline
hey to steal you thread, but I have Dual Cat-bak exhaust and its not loud enough, on the cats you have two pipes that go into one cat then into another cat, how can I take the cats out? with the cross member there? just cutt from the two pipes and cutt at my muffler and put a Ypipe into my muffler?
Adam Throop
Sig, got my exhaust system, got pics to if you wan't to see im me on "Throop13@aol.com"THaNkS
Old 04-10-2004, 11:18 PM
MontanaFord
Blue...sawzall the pipes in front of first cat and behind second cat, and have a piece of y-pipe made and swedged to fit over the pieces of original exhaust pipe and weld it shut....should work just fine...if you hafta work around the crossmember, make the back cut behind the crossmember where you can get to it with a welder....on your truck, you get caught takin the cats out...BIG fine...be careful....oh...and most muffler shops won't do the work for you...
MontanaFord
Old 04-12-2004, 12:19 AM
hixen's Avatar
hixen
hixen is offline
I took both cats out of my 92 i6 and tried 2 different glass packs both new and old and my truck is still not any louder than when i had stock exhaust. What do i have to do to get it poppin ???
Old 04-12-2004, 08:02 AM
5_labsownus's Avatar
5_labsownus
5_labsownus is offline
Received 1,675 Likes on 1,554 Posts
I replaced the complete exhaust with EFI split manifolds, Walker converter pipe, walker high flow cat (2 1/2"), flow master 40 (2 1/4") and 2 1/4" tail pipe. The exhaust shound is the best I have herd on any l6.
Quick Reply: best exhuast??
