1978 - 1996 Big Bronco
Lightning Engine Swap
Old Apr 4, 2004 | 07:52 PM
92EBBronco's Avatar
92EBBronco
I have a 1992 Eddie Bauer Bronco with a 5.8 351W. I need to replace my engine. Can I swap an engine from a 1993 Lightning into my Bronco?
Old Apr 4, 2004 | 07:56 PM
92EBBronco's Avatar
92EBBronco
If I can swap engines is a straight swap or will I need a new computer, intake manifold, or airbox?
Old Apr 4, 2004 | 09:21 PM
RLKBOB's Avatar
RLKBOB
Yup you can swap it in. Since the Lightning has GT-40 heads you may have a problem with the spark plugs but not sure. I don't know if they used different exhaust manifolds for this or not but everything alse should bolt right up(they are both a 351W).
Old Apr 4, 2004 | 10:56 PM
broncobillybob's Avatar
broncobillybob
Lightning motor, that sounds like fun.
Old Apr 5, 2004 | 12:20 AM
f1001978's Avatar
f1001978
The lighting motor has gt-40 heads not gt-40p heads, so you should be fine there.
