General Automotive Discussion
Cracked Frame
Old Apr 3, 2004 | 09:30 PM
tllawler's Avatar
tllawler
Cracked Frame
My 86 F150 frame is cracked where the steering gear box bolts on. I have had it welded twice and it doesn't hold. Do they make a repair kit for Fords like they do Chevys? Please help!
Old Apr 3, 2004 | 09:50 PM
MustangGT221's Avatar
MustangGT221
Did you drill a hole at each end of the crack to keep it from continuing? Welding it should be fine, provided it's not a crummy weld.
Old Apr 3, 2004 | 10:06 PM
tllawler's Avatar
tllawler
Theres nothing at the bottom to drill through and the crack goes all the way to the top. There is no room to build it up with anything. I don't know what else to deo.
Old Apr 3, 2004 | 10:30 PM
F2504x4's Avatar
F2504x4
can you post some pic's ?
Old Apr 3, 2004 | 10:38 PM
tllawler's Avatar
tllawler
No, I'm still driving it now but it's starting to shimmy again so I no it's cracked again.
Old Apr 3, 2004 | 11:06 PM
hreed's Avatar
hreed
Don't weld a frame "across the grain". The only way to save it is weld a structural plate. But do not weld "up and down". It will fail. Only weld along the fore and aft on a frame. Grind off all the stuff on there and take it back to the original frame. Build a plate, weld it on (not up and down) and remount the steering box. Good luck.
Old Apr 4, 2004 | 08:39 AM
tllawler's Avatar
tllawler
There is no room for a plate. You would just have to see it with the gear box off to see what I'm talking about.
