Wastegate mod?
Old Apr 3, 2004 | 06:50 PM
Uzi4u's Avatar
Uzi4u
Wastegate mod?
I bought a 99 powerstroke f250 and as I was going over it I noticed that someone had installed a small metal tube with a little hole in it between the wastegate vaccum port and the vaccum tube. I'm guessing that this is intended to delay the wastegate opening and increase boost pressure? The truck also has a superchip, could this cause to much boost? I'll be putting in gauges pretty soon but I'd like to know whats up with that tube and if I should leave it in there.
Old Apr 3, 2004 | 10:41 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Your assessment is spot on. That is exactly what it does. It's called a "boost tube", and it dosen't hurt anything.
FYI. That's a pressure line that operates the wastegate, not vacuum.
Old Apr 4, 2004 | 03:37 PM
Haulerdriver's Avatar
Haulerdriver
How long should the tube be and how big of a hole is drilled in it? I'm buying a '97 F250 HD will it work on this 7.3 PSD?
Old Apr 4, 2004 | 03:53 PM
cookie88's Avatar
cookie88
FTE Emeritus
Yeah, it'll work, but it isn't neccessary. Just unplug the wastegate actuator....does the same thing, only better.
jstihl
15
Apr 23, 2016 07:59 AM
sudsmcduff
Aug 7, 2015 10:57 PM
Crewcab Turbo
Apr 16, 2011 01:08 PM
Mr. Finch
Jun 9, 2010 08:47 AM
thedieselkid
17
Dec 19, 2009 12:39 PM
