flashers problem
Old Apr 3, 2004 | 11:01 AM
mrsuperman15's Avatar
mrsuperman15
flashers problem
my hazard flashers are goofy. they work but to make them work i have to pull the hazard button and wiggle it back and forth and then hold it at a certain pressure, then as soon as i let go the flashers turn off, what could cause this, how can i fix it, is it just age showing up on a '79 steering column? thanks for any help
Old Apr 3, 2004 | 02:41 PM
ashvalentine's Avatar
ashvalentine
The switch is bad. You'll have to replace the turn signal switch assembly in the column.
ash
['It's not hard.']
Old Apr 3, 2004 | 04:45 PM
mrsuperman15
what do i have to do to replace the assembly, how much $$, should i get a new one or go to the salvage yard
Old Apr 3, 2004 | 05:47 PM
ashvalentine
Pull the steering wheel, disconnect the turn signal arm and cover, disconnect the connector and pull it through. Installation is the reverse. You need a steering wheel puller.
Dunno how much.
Get a new one. Switches wear out and wiring ages. A junkyard assembly may be fine. Or it may not. It might last forever. Might not.
ash
['New is good in this instance.']
