changeing engines
Old Apr 2, 2004 | 06:56 PM
trailerman's Avatar
trailerman
changeing engines
i have a problem with my 4.6 that we can't find and with 182,000 miles i'm thinking about changeing engines.just wondering what pointers ya'll might have,i plan on doing it myself
Old Apr 2, 2004 | 09:10 PM
FTE Herman's Avatar
FTE Herman
What's the problem you are experiencing? You'll likely need to remove the body to R&R the motor, not an easy job.
Old Apr 2, 2004 | 09:19 PM
trailerman's Avatar
trailerman
lifter noise on right side,not always same lifter acts as if a blockage in oil flow
Old Apr 3, 2004 | 12:47 AM
buzzard's Avatar
buzzard
First and foremost, buy a Ford shop manual.
You don't have to remove the body to get the engine out, although shops are lifting the bodies to get the heads off for the head gasket replacements. You will have to disconnect all the hoses, wires, tranny, belt, hood, radiator, etc. before that sucker will come out. Like I said before get a shop manual to reference all the components and take copious notes as you proceed and label everything....it's easy to get wires, bolts, screws and hoses mixed up.
Good Luck.
