1978 - 1996 Big Bronco
Rotor opinions - need to replace
Old Apr 2, 2004 | 11:06 AM
scootin's Avatar
scootin
While I'm about ready to get into the ball joint replacement, i'm going to replace the front brakes including rotors - last time I just had them turned, and it's due for new rotors this time.
Any suggestions on type/manufacturer of rotor that is better suited for the heavy braking of the Bronco? My commute to work alone takes me down several long, hilly roads. What about cross drilled rotors to reduce heat buildup??
Old Apr 2, 2004 | 12:34 PM
Kemicalburns's Avatar
Kemicalburns
some dont like the crossed drilled because they feel that mud and stuff would get into the holes. I know a few bronco owners that have them and wheel in alot of nasty stuff and never had a problem. they did say that those rotors helped there breaking over stock for sure. the sloted rotors are good to if your worried about mud and stuff . might as well get new calipars to then if your getting new rotors.
late
Old Apr 2, 2004 | 01:42 PM
BillyBob69's Avatar
BillyBob69
I put on a set of the standard rotors from Autozone about 6 months ago. No probs since and I have towed some heavy loads up and down the mountains here.
Old Apr 2, 2004 | 01:51 PM
Kemicalburns
theres nothing wrong with the standard rotors they work great.
Old Apr 2, 2004 | 01:59 PM
BillyBob69's Avatar
BillyBob69
And no slots or holes to fill with goo when off roading.
Old Apr 2, 2004 | 02:16 PM
bronco5.8's Avatar
bronco5.8
If you go with stock rotors a good set of performance friction z-rated brake pads will do the trick. You can pick these pads up at Pep boys or Autozone parts store.
Warr
Old Apr 3, 2004 | 12:28 AM
Superman_ManOfSteel's Avatar
Superman_ManOfSteel
im with the other guys. Go with the simple autozone rotors, but if your serious about your braking then invest in some good heavy duty brakes. Dont waste the $$$ on the rotors, put it toward better brakes.
Old Apr 3, 2004 | 12:51 AM
pcwb's Avatar
pcwb
I'm running 38's on my '78 and am currently running slotted rotors, big difference in stopping with bigger tires. I haven't had any problems with mud in the rotors, seems like the heat from the brakes dries it and it falls out pretty quickly, but I'm not wheeling in the gooey flat lander stuff either.
Old Jul 16, 2004 | 11:44 AM
beastybronco's Avatar
beastybronco
what if you have larger tires? then would the heat dissipating rotors do better??
Old Jul 16, 2004 | 06:13 PM
94F150-408's Avatar
94F150-408
The slotted and drilled rotors are going to disapate heat more quickly and should help out if your running large tires.
