460 for 351m
Old Apr 2, 2004 | 10:39 AM
rogueprincipal's Avatar
rogueprincipal
460 for 351m
I have a 77 f-250 hy boy. It has a 351m in it with a 4 speed manual. The 351m has a sticking valve but I was wandering if I'm gonna go through the trouble, will a 460 mate up to the transmission of the 351m?
Old Apr 2, 2004 | 10:53 AM
Thomsen's Avatar
Thomsen
Yes the 351m bellhousing will mate to the 460...however the 351m bellhousing is about 3/8'' shallower than the 460 bellhousing. You have to make up some space inbetween the bellhousing and motor block. I put a 460 in my 70 highboy and i cut out a piece that went inbetween the block and bell that was 5/16'' thick along with the factory spacer plate that was about 1/8'' thick so it was a total of 7/16'' thickness in between the block and bell. You may also have to get different motor mounts (not sure) check landlproducts.com for motor mounts.
Old Apr 2, 2004 | 01:37 PM
rogueprincipal
Thanks for the info. This is the first hy boy I've begun. Mostly f150 4X4's. I've always wanted one and now I'm gonna do it right. I guess now I'll start with a crate motor(460 that is!)
Old Apr 9, 2004 | 08:27 AM
greythorn3's Avatar
greythorn3
spacer
Ok ive been told there is not a spacer, and then again i am told there is a spacer between the bellhousing and engine block with the 351m to 460 swap, WHAT IS THE CORRECT ANWSER? i posted about this and they keep telling me there is no spacer... then reading now again on teh forum and WHAM there is a spacer needed mentioned again. maybe we need a article on this swap in the tech section to clear it up once and for all.
Ray
Old Apr 18, 2004 | 10:29 AM
Hyperactive460's Avatar
Hyperactive460
there is a plate that goes between the engine and bellhousing, not realy considered a specer. i used 2 of them when i installed my 460. i also had a pilot bearing machined to fit deeper in the crank to accomidate the smoothe end of the tranny.
Tinterat
Apr 18, 2014 02:17 PM
oddfordjunkie
Jan 13, 2013 11:43 PM
shorty2tall
Aug 20, 2011 12:07 AM
ron_29_1973
Engine Swaps
Jan 16, 2006 10:13 AM
kp
Apr 23, 2000 08:50 AM
