Sponsored by: Real Truck
Manual locking hubs code
Old Jun 24, 1999 | 06:58 AM
latheman
Guest
Posts: n/a
I just ordered '00 F250 SC 4x4 SWB XLT with the factory standard manual hubs. The hubs show up on the vehicle order confirmation as code "21M MAN LOCKING HUB". I can't find this code in the ordering guides anywhere but kbb.com shows this code as "Manual hubs delete. Required with 213 shift-on-the-fly". I want the manual hubs. I think ##### is incorrect. For my piece of mind, could someone who has also ordered the factory standard manual hubs verify that the code is indeed 21M. And for those who ordered shift-on-the-fly, could you verify that 21M does NOT show up on your order confirmation (I don't want to leave anyone out of this little exercise). Thanks.
Old Jun 24, 1999 | 07:52 AM
sarhog's Avatar
sarhog
But you've left out all us "2WD" bubbas
Old Jun 24, 1999 | 08:17 AM
cowboy's Avatar
cowboy
I have SD250 4x4 V10 w/automatic,also ordered SOF [shift on the fly] my code is 213------$128.00
Hope this helps
Old Jun 24, 1999 | 12:29 PM
Sam's Avatar
Sam
The code for my '99 250 4x4 V10 with SOF is also 213. I've looked on my order confirmation sheet and also on the list of available options (a photocopy from the dealer book) and that code 21M doesn't show up anywhere. Maybe it's a new code for the '00 model year?
Old Jun 24, 1999 | 05:43 PM
thmprdude's Avatar
thmprdude
THE SHIFT ON THE FLY REQUIRES THE AUTO/MANUAL
HUBS THEY ARE AUTOMATIC UNLESS YOU WISH TO LOCK THEM IN.. THEY WORK GREAT
Old Jun 24, 1999 | 06:21 PM
locoman's Avatar
locoman
My 99 that is almost here has manual locking hubs and the code is 21m. so you should be all set! good luck with the new truck can't wait to get mine.
Old Jun 25, 1999 | 08:30 PM
J.C.'s Avatar
J.C.
Old Jan 25, 2017 | 11:50 AM
Daniel Davis's Avatar
Daniel Davis
Auto locking hubs have more electrical problems manual hubs basically flawless. I just think that less parts is better
Old Jan 25, 2017 | 01:12 PM
acecase's Avatar
acecase
I have (had) the auto lock hubs. Bought a set of Warn manual hubs, removed the vacuum lines, auto hubs, and the screw in vacuum nipple on the back of the knuckle. Filled that hole with a 1/8" NPT pipe plug and capped the vacuum solenoid output on the right side of the radiator. I then installed the Warn manual hubs. Now can use 4 low in 2 wheel drive (2 low) and get awesome torque with bind freesteering with the simple turn of the lazy ****. I love it like this.
hi-jacker
May 15, 2017 10:19 AM
rrthor
Oct 19, 2016 05:30 AM
Spoojr
Oct 10, 2016 11:52 AM
BillBraskey
Jul 29, 2016 03:01 PM
droldsmorland
Jul 12, 2016 08:40 AM
