Sponsored by: Real Truck
Noise after engine is turned off
Old Jun 30, 1999 | 11:03 PM
Mark Cosgrove
Guest
Posts: n/a
I have a 99 250 SD with a V-10. It has only 500 miles on it now. I have noticed a loud metallic "ping" while the engine is warming up or cooling down after being turned off. It occurs about every 5 or 10 seconds. It seems to be located near the exhaust pipes before the catalytic converter. Is this normal? Is it part of the breaking in period?
Thank you.
Old Jul 1, 1999 | 02:01 AM
V10 MAN's Avatar
V10 MAN
It is normal. Mine pinged like crazy! I can't remember just how long it took to stop. I got used to it to the point that I didn't notice exactly when it quit. I don't even get one ping now.
Old Jul 1, 1999 | 03:04 PM
doug's Avatar
doug
Yep, mine used to do it also. I think it has to do with the exhaust pipes expanding and contracting with the heat and cold.
Just like V-10 man, I got used to it and then it stopped after a while. I believe it was around 7,000 - 8,000 mile area. My truck has the 5.4L V-8, so it does not have to do with the V-10.
Doug.
Old Jul 1, 1999 | 05:11 PM
fjord's Avatar
fjord
My F350SD V10 did the same thing. The noise derives mostly from heat shielding on the exhaust beginning near the front of the cab but comes from several points along the system.
Old Jul 2, 1999 | 11:45 AM
Don's Avatar
Don
Old Jun 8, 2007 | 04:32 PM
mrofb's Avatar
mrofb
My F 250 with a 5,4 V8 does the same thing. After a while you don't even notice it.
It is not as bad as it was when I first got the truck.
